What does this mean? 3
ryandias
Automotive
Jul 28, 2006
197
see attachment.
getfile.aspx
Are you asking about the +0.1 surounded by red, or something else on there?
Yes the callout in red.
It looks similar to a weld symbol but that makes no sense in this instance.
Maybe it's the contrast on my monitor, but I can hardly make it out. I'd almost guess chamfer based on what I can see. Someone more familiar with ISO/DIN std's may do better.
I'm pretty sure I've seen similar before but can't recall the details.
It is explained in ISO 13715:2000 an international standard for defining "Edges of workpices"
Since it is a published standard I cannot post its contents.
Paul
I am familiar with some... work with them?... occasionally to interpret "decode" as Bill Tandler says.
Oh and I should have said "Edges of Undefined Shape" rather than "Edges of Workpieces" possibly just a Ford-speak.
Paul,
I think I'm clear it is to do with the edges,
but what does it specify? rounds? chamfer, burrs?
It specifies that a raised edge of up to .1 is allowable.
The plus figure is a permissible burr and the minus figure is a permissible rolled edge as you typically get with stamped/ blanked parts.
Since it is on the vertical portion of the corner then the permitted raised edge may extend 0.1 past the horizontal part boundary... there should be no extension past the vertically shown boundary.
If the spec was in the corner of the symbol the permissable burr direction woud be unspecified.
Paul
Ryandias - DIN 6784
Symbol Outside corner Inside corner
+ burr transition
- free of burr removal (metal)
+/- burr or burr free transition or removal
In your case (marked in red)= outside corner burr up to 0.1
The upper -0.1/-0.3 calls for no burr from 0.1 to 0.3. Removal (metal) is your choice.
