Problem loading Cadkey99 on SW machine.
AlbertH22
17
For some reason '.prt' files are associated w SW so you have to change 'opens with' from sw to CKwin. Now in the folder options / files types dialog box the 'advanced' button changes to 'restore' so you can't get at the 'advanced' action 'edit' screen bs to fix the problem of mutiple sessions of cadkey when you open files from explorer. Any one can help wit this Id be much happy.
Solved. (I deleted the 'prt' file extension from the file types dialog and then I added it back as 'new'.) So thanks Albert!
