nstcook
- Sep 15, 2000
- 1
Hello everybody!
Presently starting to design an XY table for short but fast strokes of a few mm at a time. The peak acceleration is to be about 120 m/s^2 with a 5 kg load. Using 6mm dia. crossed rollers. My major concern is dynamic stiffness of the table. Also Yaw and Pitch errors should be within 5 arc seconds over the total travel range of about 70 mm for each stage. The unusual part about this project is that the linear motor driving the bottom stage (X stage) is located directly below the stage and exerts a huge vertical magnetic force (~200 kg) on the stage, which would heavily preload the linear bearing. Any inputs in this matter would be greatly appreciated; especially as regards mounting, preloading from the side, appropriate materials etc.
Thermal management is also important since the motor is very close to the crossed roller rails and any differential expansion between the stationary rails and the moving rails on the X-plate would change the preload. Your comments and suggestions on these and other relevant issues are welcome.
Thank You!
-nstcook [sig][/sig]
Thank You!
