Writing to serial port
chimc
I want to write a charactor string to the serial port on a mitsi PLC e.g an FX PLC to then be written to a GSM Modem, for example write a program to send a text message from the PLC via a GSM Modem when a alarm is generated ?
Any ideas please ??
I recently performed the same task using a different PLC. What is the model of the PLC you are using?
Probably be a Allan Bradley SLC 5/04
