WoodrowJWeen
- Jul 30, 2003
- 112
I'm working on a project that will have over 70 wind turbines mounted on a building. Each turbine will have a generator with a max output of 10kW, (120VDC @ 80A). I'm looking for some inverters that could be used to produce 480VAC, 3 phase output. These would synchronize with the grid and offset some of the building power demand. Does anybody know of such an inverter? We would like these to be rack mounted, possibly in a setup like a motor control center, where each unit had an output breaker. We often specify VFDs in an MCC, this seems like a similar arrangement. I just haven't found this offered from the usual MCC manufacturers.
Yes, the building main switchgear will have reverse power relays to prevent backfeeding the utility.
