MoMiner
- Oct 12, 2006
- 3
I am designing a wide flange beam joined in the middle with flats on either side of the web and one on the top flange. How large can I (or should I) make the fastener for the top joint plate? There will be 1 hole each side of web and each side of joint. I am working with a W6 x 12lb beam, 1/2" bolts, but might consider 3/4" if the holes don't weaken the top tension loaded flange too much.
