Why do we simulate Tensile test ?
farzadtb
38
Hi All
I know it might be a basic question for you guys
but since I have not dealt with this , I would like to ask , we do the tensile test only when we have to know the material behavior, once we know that, why should we simulate it ? definitely we don't know the material stess-strain behavior if we have not tested if before
Thank you very much
When I am given uniaxial stress-strain data I will often perform a single element tension test to verify that I have defined the material model correctly in the FEA code. Takes 2 minutes and gives confidence in the model.
Dave
thank you, shall I ask you how do you verify that?
Not sure what you mean. For what I described:
[ol 1]
[li]Take the uniaxial stress-strain data which you have generated or taken from the literature.[/li]
[li]Use it to define the appropriate material model (elastic-plastic, hyperelastic etc.) in the FEA code.[/li]
[li]Perform a single element uniaxial tension test to replicate the conditions under which the test data was generated.[/li]
[li]Verify that the FEA output matches the measurements from the test.[/li]
[/ol]
Just a simple test to check a material model is defined correctly. I'm sure there are other reasons to simulate a uniaxial tension test? Maybe it is useful to people who modelling damage/failure or developing user-defined material models?
Good luck,
Dave
Thank you Dave
I think I need a bit more elaboration
let's say we have test results, with a yield stess at 320 MPa @☺0.02 of strain , then 500 MPa @0.1 strain and 800 MPa @2 (strain) - I know there are just three point , let's say we have a full diagram
then we do the analysis, I see the material has yielded at 800 MPa
If we assume that the correct and real UTS was 750 MPa , how am I gonna justify it with that single element analysis ??
In that case you are not going to justify your material model???
If you define your material model using uniaxial test data and run a single element tension test, your FEA output should match your test output. If the they match, you have verified the material model. If they don't match you made a mistake defining the material model.
Dave
Thank you Dave, but you know that yet I have not understood you? Shall you please exemplify numerically?
Sorry, I've explained as clearly as I can three times now.
What part does not make sense?
Dave
