TMcRally
Automotive
- Aug 17, 2007
- 155
Hi
I am trying to make some sense of the technicalities of the Whiteline ALK or as they now call it WALK. Not sure if you are aware of it but it lowers the rear height of the front lower control arm by about 20mm. It also moves the arm away from the centre of the car to increase Castor. I'm Ok with the castor side of it but the lowering of the arm I am having some trouble understanding.
I'm not sure I agree with the working out of the SVIC and I'm not sure if/how this is providing a benefit.
The kit will also increase the SAI which is already around 15 degrees.
I can only see a softening of the effective spring rate which provides better front end grip, and we get more castor (maybe good maybe bad) and a firmer bush.
Am I missing something.
Dave
Dave
