UW1981
- Oct 25, 2005
- 38
We are moving a vessel to use in a different service (absorber to amine still). The vessel was built in 1965 using SA-212 B Firebox, but does not have a min. temperature stamped on the plate. I believe at that time, the code allowed -20F for this material. Since I am moving the vessel, I would like to comply with current code (internal policy). Given this, I was going to use API 579 to determine the hydro pressure I need in order to get the -20 F MAT I want. In order to do this, I need the UCS-66 Curve MDMT...but I am not sure which curve to use. The vessel is 1-7/16" thick (yes....way more than I need for the still...but the vessel is in our stock). Although the code indicates the replacement material for SA-212 B is SA-515/516-70, I am very hesitant to use Curve B for the MDMT. I have not been able to find anything on any interpetations regading this issue. I believe the right thing to do is use Curve A for the UCS-66 MDMT (as a non listed material) and then plug this into the API 579 hydro MAT reduction calculation. Is this the right way to go about this?
