Which has a lower processing overhead?
PeterGuy
Automotive
Jan 15, 2003
249
I am writing a program process data from an analogue capture card and am going to push the data into excel. There are two way I know of achieving this -
Directly by setting object references to excel and putting the data into the cells.
or
Using ADO with excell as the DB.
Which one of these has the lower processing overhead in the parent application/thread.
Many thanks
Pete
writing (and reading) data directly into excel cells is in my experience orribly slow, no direct experience with ado interface and excel. Consider writing data in text file and the import with excel (this is fast).
have a good luck
I am supporting both txt & xls storage formats & bench marking to determine the maximum sample rate. FYI: to write 18 doubles to excel with .EnableCalculation = False & .ScreenUpdating = False takes 15ms on a P4 2000, 26ms on a AMD XP1700+ & 120ms on a PII 500 and thats with out sampling & number bashing. it's also unfortunate as the the target m/c is the PII as it is currently unused. On the bright side the logging requires a slow rate (currently done manually every 10 mins).
Many thanks
Pete
I have just run the same test with timers on txt files & result is as follows on AMD1700+ 18 doubles every 0.036768ms writing to an open file. Opening, writing & closing comes out @ 2.5958ms for the same 18 doubles
Hummm
Pete
