AAEC
- Nov 22, 2006
- 42
We are planning to construct a concrete secondary containment with a sump to drain out either rainwater or other liquid mix. In order to drain the liquid inside the containment, an inlet pipe will be connected at the sump directly either to an existing drainline pipe or to an existing concrete catch basin. My question is where should I connect the pipe? Should it be to the existing drainline pipe or to the existing concrete catch basin?
