what materials should i chose?
yuy
Industrial
Sep 15, 2002
9
Mostly make for baby toys.
is that ABS is prefer to chose?
Any suggestion on it?
i don't know the process, just a small toy box.
In my view, it should be used with ABS and injection molding.
here some of the information:
Expected Production Qty / Day = 800 pieces / 10 hour injection shift.
Plastic Injection machine capacity = Range from biggest 350 Ton / 32 oz, 200 Ton / 22 oz, 150 Ton / 16 oz, 80 / 4 oz
Does it have an increased strength requirement? Polypropylene might well suffice your need and will be a lot cheaper. PE might do well too. It depends on what the toy will have to withstand during it's lifetime. You should speak to a material supplier and they will be able to advise you.
That's a good idea...
Thank you
