What is the use of Vertical Offset command in SAFE12
monver
3
I have noticed that by providing the vertical offset in SAFE 12 a very impressive 3d graphic display is generated. There is no physical change in the actual model as neither it effects the deflection values nor any slab moments. So I don’t understand why this command is there? Do anyone know what is the use of this command? I have to use release command in slab.
