What is the overstrength factor used on the Allowable stresses Table for aluminum beam
structure567
50
I need to do some aluminum beam design and had some questions on Aluminum Design Manual(ADM) Part VI Table 2. This table shows the allowable stress but is shown as F/Ω. It does not specify what the omega value is... Does anybody what the over strength factor that is used?
If this table is for allowable stress, which expressed in F/Ω, then is that necessary to know the value of Ω. It could be a varying safety factor, and can be derived by F/allowable stress listed in the table.
I would like to know the value because I'm not sure which safety factor is applied. I dont know if I'll need to apply another safety factor on top of the one already applied.
I've explained how to derive the value of Ω in my post, provides you know what is "F" representing, and are certain F/Ω is indeed the allowable stress. Try some cases to see if the resulting safety factor make sense or not.
You'll need to reference each section of the ADM specification to see what the Omega factor is. Below is a snapshot from Chapter F which governs the design of members for flexure. As you can see below you'll have a couple different omega values depending on your governing failure mode and what type of structure you're designing.
