dspDad
- Sep 6, 2003
- 56
I was at oskosh this summer and took a demo flight in an (unnamed) gyrocopter. Thoroughly entertaining, but somwhat discomforting for a fixed wing pilot.
After seeing how squirrely gyrocopter handling is, I started researching gyrocopter flight characteristics, which led to asking questions about helicopter flight characteristics.
Because of helicopter wing precession, are the forces generated through the swash plate orthogonal to the desired motion, e.g. apply a force up or down on the front of the blade to turn right/left, etc.
Or will applying an upward force at the front of the blade (admittedly by increasing the angle of attack as it passes in front of the helicopter) cause the helicopter to
pitch up like in an airplane?
I asked a gyrocopter guru about this, but instead of an answer got a comment that the gyrocopter I had tested is one of the more stable gyrocopters out there. (With the implied and probably correct assessment about my cowardice)
The second question is the same, only about gyrocopters. Does swinging the body of the gyro forward and back cause a change in pitch or roll, or some combination? Because the linkage was through a floor mounted stick, I don't know what motion I was really imparting to the blade.
