Metrics
- Nov 16, 2005
- 17
Does anyone have thoughts on TIG welding Inconel X750 to 316L stainless steel?
I want to weld a 3/4" "rod" of inconel to a "thick wall tube" of 316 (3/4" id). The parts would be slid together so the ends are even and the welded at the interface of the two parts. No filler metal.
Inconel would be in the precipitation hardened condition, 316 in annealed condition. Service temperature is -45 to +200F.
Is this a no problem weld or does it require special setup?
Thanks for any advice you can provide.
