apropos
- Mar 22, 1999
- 9
I am quoting on an aluminum tube assy that has a sheet metal pad welded to one end. Material is all 6061-T6.
There is a weld symbol with a process or specification reference, RE-PS-28-3 CL-B. Also there is written "Weld per IAW G-F401. IAW could mean "In accordance with" or International Association Welding? The part is old Fairchild or Northrup aircraft if that helps.
Thank you for your help,
David B.
