WELD COEFFICIENT IN RAM CONNECTION.
FabioBorini
6
i AM TRYING TO DESIGN A SIMPLE SHEAR PLATE USING RAM CONNECTION, AND WEHN I WAS LOOKING AT THE REPORT I COUDNT FIGYRE IUT HOW DID THE SOFTWARE CALCULATE THE VALUE OF THE WELD COEFFICIENT, WHEN I DID THE CALCULATION MANUALLY IT GAVE ME A DIFFERENT VALUE:
HERE IS HOW THE SOFTWARE CALCUATAES THE WELD STRENGTH:
Verification Unit Capacity Demand Ctrl EQ Ratio References
Weld capacity [KN] 666.06 111.80 1V - SL 0.17 Tables 8-4 .. 8-11
fRn = f*C*C1*D*L = 0.75*0.92509[KN/mm]*1*4*240[mm] = 666.06[KN] Tables 8-4 .. 8-11
#AND ATTACHED IS THE DIMENSION OF THE CONNECTION
 http://files.engineering.com/getfile.aspx?folder=786aeb14-6dba-4d15-aedb-23726abcc091&file=001.JPG
