somarp
- Sep 14, 2004
- 7
I need some help - I am working the CG work for a new machine. I know the estimated weight of the unit and now I am trying to determine based on the CG location weights on each wheel.
I have done the reverse in the past by using weights from each wheel and calculating the CG location, but for some reason going in reverse is causing me problems.
Here is the example I did in the past - even with this one I can not work it in reverse to calculate the weights on each wheel.
Machine weight = 42100
Left Front Tire (LF)= 6980
Right Front Tire (RF)= 14900
Left Rear Tire (LR)= 12620
Right Rear Tire (RR)= 7600
Wheel Base = 72.65
Tire to Tire Dimension = 91.22
To find "X" location of CG I did:
(7600 + 14900) * 72.65 / 42100 = 38.8"
To find "Y" location of CG I did:
(6980 + 14900) * 91.22 / 42100 = 47.4"
Any advice or comments on calculating this backwards would be greatly appreciated.
Wheel Base = 72.65
