Hydrostru
- Dec 15, 2010
- 12
I am designing a 10' by 10' by 7' high concrete riser which will be connected to a 5' concrete pipe, as an outlet for a pond. The riser is cast in place around the pipe and riser walls will be 8" thick, do I need to provide some waterproof method around the connection between the riser and pipe? I was thinking to pour flowable fill around the connection or apply "second Water Proofing Method" around.
Any help will be appreciated!
