Visual Basic BeforeSave Sub 1
Clyde38
533
I have included an automatic save subroutine using the Private Sub Workbook_BeforSave.... funciton in the VBA editor. I am using it to save to a particular path and file name. This works fine until I add a new worksheet to the workbook. All other additions or changes to the existing workbook will save automatically when I save the the workbook. What's up? See below..
I do not do many VBA programs. This is a variation of an Excel tip that I read.
Private Sub Workbook_BeforeSave(ByVal SaveAsUI As Boolean, _
Cancel As Boolean)
Dim rngPullName As Range
Dim strSavePath As String
Application.DisplayAlerts = False
Set rngPullName = ThisWorkbook.Sheets(5).Range("A4")
strSavePath = "C:\Spreadsheets\myfilename\"
ActiveWorkbook.SaveAs Filename:=strSavePath & rngPullName & ".xls"
If ThisWorkbook.Saved = True Then
Cancel = True
End If
Application.DisplayAlerts = True
End Sub
Suspect that this may be your culprit:
Code:
If your new sheet shows on the tabs before position 5 then rngPullName may well be empty. Use the sheet name instead
Code:
Set rngPullName = ThisWorkbook.Sheets("sheet5").Range("A4")
substituting the actual sheetname of course
Good Luck
johnwm
________________________________________________________
To get the best from these forums read faq731-376 before posting
Steam Engine enthusiasts:
Thanks - You're welcome!
Good Luck
johnwm
