Viscoelastic material for damping high frequencies?
GMarsh
123
Hello all,
I would like to know if there is any viscoelastic material that is more suited or designed to damp high frequencies - 15000 - 16000 Hz ? I mean having loss factor near to 1 around this frequency range? Most of the commercially available tapes are designed for 1000 Hz range.
Thank you
Geoff
I don't have the exact answer but do have some clues.
Damping is achieved by lossy materials (materials that are soft but inelastic). I.e. in the DMA curve they have a high tan delta value (loss factor) in the frequency range you're interested in. Usually higher mass is good too, for example using a dense filler like barium sulfate or magnetite.
At higher frequencies materials behave more stiffly and elastically. So, you need to use a material with very low glass transition temperature (Tg). I know you can buy Sorbothane mats. Do they work at that frequency?
Chris DeArmitt - PhD FRSC CChem
Are you damping a one-time event (shock) or a continous 16 kHz frequency? I know that, depending on thickness, epoxy can provide reasonable damping at ultrasound freq. At 2-10 kHz, we saw good shock damping with thin silicone elastomers from Lord Chemicals. Big hint on that last one there - they are experts on the subject.
Thank you for all the responses.
Presently I am using 3M ISD 112 tape whose loss factor droops to 0.3 by 10kHz. It's greatest loss factor is around 1kHz.
It is not a shock event, but a forced vibration at 16kHz.
Demon3 - Can you please explain what you mean by 'higher mass is good too'. Do you mean to say that instead of traditional 5% of vibrating mass, should we go for 10 or 20% while designing tuned mass?
I am actually looking for something sticky tape - like that of 3M Viscoelastic tapes. If I get non-sticky polymer I may have to again think of using some adhesive to mount it on structure.
I will contact Sorbothane and Lord Chemicals. Thank you for your suggestions.
Kind regards
By adding mass I mean that usually such compounds are filled with dense particles to increase their mass. The more mass you have to vibrate, the more energy it takes.
Yes, but theoretically one should add damping also along with mass to damp out the split modes caused due to tuned mass. So I am looking to add damping tape which has highest loss factor in that frequency zone of 16kHz.
That's what I said. You choose a lossy, damping material and add mass by filling it with dense particles.
