eljas
Marine/Ocean
- Feb 12, 2007
- 10
Currently in our ship project has VFD (Variable Frequency Drive) been used to start and ramp up 3.1kV/60Hz/2-pole/5400kW electric motor for Compander.
Ship power network have 4 pcs 6,6kV/3800kW/60Hz Diesel Generators whereof 3 is running when motor is started. Sufficient capacity to start the motor with VFD.
VFD Data (IN):
Voltage 2x1800V eff
Current 970A eff
Frequency 60Hz
VFD Data (OUT):
Voltage 3150A rms
Current 1170A rms
Frequency 60Hz
V range 0-3150V
F range 0-60Hz
Q1: Can Soft Starter do the same job?
Q2: Has been proven earlier in other shipbuilding projects and what is requested from the power network?
If this could be possible, a significant cost saving is possible.
VFD Data (IN):
Voltage 2x1800V eff
Current 970A eff
Frequency 60Hz
VFD Data (OUT):
Voltage 3150A rms
Current 1170A rms
Frequency 60Hz
V range 0-3150V
F range 0-60Hz
