eeromatti
- May 10, 2006
- 25
It would be helpfull if user was able to input weight of the vessel in support calculations. It's usually the case that vessel weight calculated by compress is different than actual vessel weight and I have to correct vessel weight in compress by adding equal mass that makes vessel weight correct.
But our quality manager and AI can't accept this because Compress prints on "Settings summary" that UG-22(c) (external loads) have been taken into account which is not the case.
Another solution would be editing xml code of report.
