anchorengineer
- May 26, 2009
- 88
I'm designing a shelf angle for brick veneer. I'm going to anchor this angle with post installed anchors at specific intervals along the span. The bending capacity is not a concern to me (Although I will check bending along the angle and shear at the anchor points). It is the length of the horizontal leg that I'm worried. After reading through BIA 31B it seems I just need to make sure that the deflection of the horizontal leg is less than 1/16". I'm still going to check the horizontal leg as a cantilevered beam fixed at the wall and check for bending and sehar as well. Does this make sense? Any suggestions?
Thanks!
Thanks!
