pietro82
Automotive
- Mar 14, 2012
- 189
Hi all,
For a project I have to perform some fatigue analysis of a commercial vehicle with a fpivoting front axle with no suspension system (i.e. the axle can freely rotates along the vehicle longitudinal axle). The aim of the analysis is to rank the most common tasks according to their pseudo-damage. Since we have a tight schedule, we need to install sensors on several vehicle samples, therefore we have in mind to perform a fast analysis using accelerometers instead of strain gauges. So in first instance, we need to check the methodology, therefore I have installed 2 accelerometers at the wheel hubs to measure the axle vertical accelerations and 2 strain gauges to measure the axle vertical load and then I drove the vehicle on some hard surfaces. The verical load signal on the left side almost overlaps the one on the right side due to the type of suspension. I have double integrated the accelerations to get the displacement and after that I have removed any signal drift due to the numerical integration. As stated in other papers there is a high correlation between the displacement and vertical load, upper than 0.9.
What surprised me is that in the left side the correlations is positive (i.e. the displacement increases with the increasing of the load) and in the other one is negative (i.e. the displacement decrease with the increasing of the load). How is that possible?
Any suggestion is welcome.
cheers
