warmblood
Mining
- Jul 12, 2005
- 3
I need to construct a variable pitch helix on a diameter 200mm circle(drawn on the top plane, on the origin), 4 revolutions, clockwise, starting at 270 degrees (on the front plane). The pitch is initially 100mm (rev 0) and must be gradually changed to meet a point 350mm vertically straight under the starting point of the helix (also on the front plane).
By simply tweaking the pitch in the table at rev 4 to a number of values, I have found this value to be 75.
How can I work this value out each time instead of tweeking the last pitch in order to reach my 350mm specified height?
This can save me a lot of time since I need to create a number of variable pitch helixes that needs to go through specified points.
Please help
Please help
