schick
- Nov 1, 2001
- 49
This may be a very simple thing, but I'm just getting started with ProE 2001....
Is it possible to have a part, for example a piece of pipe, with different lengths, under one part file?
I understand how to use the Family Tab function. I was more interested in being able to insert a basic cross section, type in the variable dimension, and insert it into an assembly. Where if I require different lengths, I can just add another component, instead of opening the part and adding a new instance every time.
Thanks for the suggestions!
Eric
Eric
