noideahow
- May 3, 2012
- 8
some info,
goulds variable frequency drive
12 hp motor
230 gallon a minute
2 119 gallon water pressure tanks
psi of tanks set at 48
psi set at 63
commercial business
Was wondering if i would need more tanks? seems like my pump keeps cycling without turning off for awhile. ( goes to 61 then down to 53 then up to 61 then back down. pump doesnt shut up unless this happens like 3-4 times. does anyone know if i need more thanks or if i should decrease psi? is this bad for the life of my pump?
12 hp motor
230 gallon a minute
psi set at 63
commercial business
