Renoyd
- Feb 11, 2007
- 41
What would be the proper methodology for sizing a control valve with liquids flashing downstream?
Fisher recommends allowable pressure drop method that results in a larger valve than using actual pressure drop. The question is, how can I get the required pressure drop if the much lower allowable pressure drop is used for sizing?
Any idea or commends would be appreciated.
