User Commands
dwppnp
Is there an efficient method of converting side bar menus to user commands?
There are a lot of user commends. For example "AA=90" will change the active angle to 90 degrees.
dwppnp,
There is a way you can do that, go to workspace>Function Keys... A dialog box will open. In here we have the ability to make commands. Using the shift key, ctrl key,alt key. This will give you 48 commands. Hope this helps.
Namdac
Actually, you can have virtually unlimited commands using the function keys.
Simply by making a few command files {each with different commands that you would want to use} then dedicate 1 or 2 function keys {with the shift/ctrl/alt that's up to 6 different command files} for switching between those files. Of course, you might want to map all those lovely commands and print it out so you remember what's what.
For an exciting SciFi/Fantasy anthology by new author Matt "Dra'Gon" Stohler, go to
