update ansi to asme dimension stds
Dickie
New member
Feb 27, 2002
I have a model created with ansi text and dimension standards. I am creating a new drawing from this model but with asme stds. The text and dimension standards are different (text thickness, arrow head length).
Anybody know a macro to update this? right now the only way is to recreate the text and dimension. I have run 'annd34'
pls change the std which u need & update ur drwing u will get all the dimentions changed as per ur requirements...thax
I still have a problem with V3 dimension extension lines arrows, not being able to update them to V4 ansi std's.
The only way is to re-create them!!!!
The arrow heads are coming in smaller.
Any help would be great.
Try also DIMENS2 / MANAGE / STARTUP, then select a startup model with the standard you want to set.
