rika kose
Chemical
- Jun 11, 2019
- 71
A client uses centrifugal pump to unload HCL35% solution tanker.
But the pump can not prime. Client makes a side branch pipe to a bucket in the suction line of the pump.
Operating:
1. Connect the unloading hose with bottom valve of the tanker
2. open the discharge valve and start the pump
3. Open the branch pipe and let HCL35% fill the bucket around 2L then the pump starts pumping
4. Close the side branch
So, it shows that the pump can not be filled by gravity (Gas/air in the suction lines). We solve the problem by installing a self-prime pump.
My question is that why the pump cannot be filled. Due to physical properties of the solution?
The similar installation is used to unload other materials, never had the same problem.
Operating:
