nealc
- Feb 26, 2003
- 5
I am trying ot create flow graphs based on a calculated Cv value, with pressure loss shown in PSI.
Function works and gives me default units of lb*ft^-1*sec^-2, at which I insert psi and all is well
However, when I try to graph it, I get the default units, if I type psi in the y column I get changed, but wrong results. Does anybody have experience in creating graphs where you change the output to a "non-standard" unit??
