ChEMatt
Chemical
- Jun 28, 2005
- 146
Looking at an 1100 psig (well gas, free water and oil removed, compressed into a pipeline) gas stream used for fuel gas at 100 psig. In reality, the depressurization of the stream through control valves causes a nice ice block to form over the valve and nearby piping. In Hysys, the outlet temperature is 38F, nowhere near freezing.
I'm using a recent gas analysis, so I believe it to be correct (and I've got nothing else to go on, so if it's wrong there's that). Is there something I should be doing to improve the temperature depression prediction to get something more accurate to reality? I'm using the Peng Robinson EOS, standard hydrocarbon components up to "C7+", using the "saturate" extension of Hysys to saturate the stream. We're pretty close to sea level, so no significant changes in absolute pressure are needed.
Am I forgetting something?
Thanks!
-Matt
Thanks!
-Matt
