PAP
- Jul 7, 2002
- 37
Hi all
I have a question about the under voltage protection for the main incoming of industrial plant. Its main incoming has only one feeder @ 22kV and connect to step down transformer (to 400V). Some problems were come from under voltage relay and undervoltage release coil in the main circuit breaker (@400V) .So I want to remove this function from the system, are there any concerns about this function? I don't understand that why under voltage relay must be used in this simple scheme.
For the motors ,under voltage protection was cover by overload already,right?
Thanks all for your sharing
PAP
PAP
