MramJ
- Aug 26, 2023
- 6
Could someone please explain how to evaluate bearing capacity using ULS? (I'm in Canada, if that makes a difference.) I have tried finding answers and reading reports, but I never clearly understand how ULS and SLS are calculated.
1) Is ULS a factored ultimate bearing capacity? If so, why do some geotechnical reports mention "Factored ULS"? Isn't that double factoring?
2) Is ULS the same as the allowable bearing capacity? Is ULS calculated as ULS = q_ult/FS where FS = factor of safety?
3) How do you determine SLS to limit settlement to x mm?
Thank you.
Thank you.
