Stress_Eng
Aerospace
- Jun 15, 2019
- 227
Having worked in the Aerospace industry for a while, I’m under the impression the FE analysis of pin loaded lugs is a common occurrence. With todays FA software package capabilities in contact analysis, I’m interested to understand the standard approaches used in deriving the linear surface stiffness used in the over-closure penalty approach. I have an Aluminum lug loaded by a steel or titanium pin. With different materials, I’m considering using an effective modulus based on the Hertzian contact method. I’ve seen suggested factors applied to the modulus between 5 and 50. I’m interested to know if a more specific value can be derived. In addition, I would also be interested to know if a target penetration depth is used as a basis. Any suggestions would be much appreciated.
