Two questions...
Kenja824
Automotive
Nov 5, 2014
950
QUESTION 1
Every day when anyone starts up NX, the info window comes up with this message (marked 1 in the image). It is a file we still use but was created a long time ago by someone and as it is a DLL file, we cant open it and change code or anything. Is there a way to get NX to just accept it without giving this warning?
QUESTION 2
When I open a file, it gives me the report (marked as 2 in the image). You can see by the size of the scroll bar (circled) that this seems to list every item loaded. Is there a way to turn this off so we dont get the report when we open a file?
Neither of these problems are big problems. It is a single click to X out of it. Still, if either of these are simple fixes, I would rather do so.
Ken
My brain is like a sponge. A sopping wet sponge. When I use it, I seem to lose more than I soak in.
Hi
Question 1
You can turn this off in Customer Default.
Regards.
Mattias
NX5 -> NX12
Testing NX (1899)
I-deas 12, NX I-deas6.6
Solid Works 2017
Thanks Mattias! That definitely fixed that problem. I.T. has been trying to figure that one out for a while. :)
Ken
I guess the "2" is a setting "display update report" ?
It's a customer default : Assemblies - General - Miscellaneous -Display Update report.
One can do the same report manually : Menu- Information - Assemblies - Update Report
Tomas
Never try to teach a pig to sing. I wastes your time and it annoys the pig.:)
Hey Tomas
I dont find that particular setting. I did find a "Populate Simplify Assembly Dialog" setting.
When I unchecked that, it did not give that full report, but it did still open a blank info window. Which seems silly to me. So either way I have to close the window. Not a big deal. Just curious if there was a way to eliminate that from opening at all when I load a file.
Ken
This is the Customer Default Toost motioned.
Picture from NX2000
/Mattias
NX5 -> NX2007
Solid Works 2021
You know what? My eyes passed right over it because it is all greyed out. Must be something the Admin has locked out. Thanks to both of you for the help. :)
Ken
