cranky108
- Jul 23, 2007
- 6,293
Has anyone sucessfully been able to apply a trip circuit monitor on a circuit with a lighted nameplate lockout?
The problem dosen't seem to be in the reset state of the lockout, but in the tripped state there is an interaction between the lighted nameplate and the trip circuit monitor.
The issue is that someone had this wonderful idea to place the lockout in a 35 kV switchgear, but the transformer differential relay was placed in the control building. The lighted nameplate trip coil monitor monitors the trip coil, but leaves much of the circuit without monitor. The trip circuit monitor monitors a greater part of the circuit. During testing it was found that the two monitors interact while the lockout is triped. This interaction was on the order of several thousand outputs of the trip circuit monitor a miniute.
I have contacted both venders, and nether were helpful in providing a solution. The lockout out vender has really made my list, because i had contacted then prior to the instalation, and they did not have time to discuss it with me. And after the instalation they have provided very little (OK they had a huracane, but they appear to have a sustanability problem also).
Any ideas to a solution?
This is a utility application, and the schematics are very utility common.
