Transfering Assembly Datums/Axes/Features To Part
Laserxenon
45
I sometimes am basing the placement of a feature in part "A" dependent on how things are coming together in assembly "ABC" which consists of Parts "A", "B" and "C".
If i create say a axis or hole in assembly "ABC", how can i transfer or reassign that feature to part "A"? You can imagine that i can see right where i may want to place a new hole when I am looking at my assembly "ABC", but I need the hole to exist on part "A", not in the assembly. If its not possible to create the feature that way (hole for example), I could also live with creating an axis that would similarly be transferred to part A so that i could reference that in the part to create said hole.
Thanks for any suggestions you can offer and please let me know if that isnt clear.
Drew
There are at least a couple of ways to do this. The simplest is to create the hole in the assembly and tell Pro/E that you want the hole to exist at the part level. There is an option for that in the feature dashboard. You can also use copy geometry and/or skeletons to move geometry from the assy to the part.
Dgallup,
Thanks for your reply. I played around with it as you suggested, and was able to find how I can assign the feature (hole for example) to be created at the part level- cool stuff.
The one thing I couldn't find however was how to create an axis or datum and similarly assign it to the part level. I did try creating an axis in the assembly, copying it, then switching to the part and pasting it, but it didn't seem to work. I am not very versed in skeletons so I started watching a video tutorial, but I am hoping that there is a way of doing it as easily as creating a feature as mentioned above!
Thanks for your thoughts,
Drew
