Shockdesigner331
- May 13, 2005
- 69
Hello all. I need to design a quick and Simple torsion spring tester.
About the spring to be tested:
-Deflection angle required = 105°
-Anticipated Torque required to rotate to 105° = 70 in-lbs
-Number of cycles needed = 100k
My idea (by no means am I thinking this is the best way, but probably the easiest):
I have access to a pneumatic ROTARY ACTUATOR that I can control the angle of deflection to meet what I need and it has more than enough torque (actually overkill) but I have no experience in automating the rotation cycles. There are limit switches that could be purchased for the actuator.
Anyone have any ideas? If I could just supply air to the one side for 1 second, release, then supply air to the other port for 1 second and release - then repeat this cycle...
