Toggle Between Drawings
mikeo56
28
There must be some quick shortcut to toggle between two or more drawings opened?
Thanks, Mike.
Ctrl-F6 usually works
Alt-Tab also works
Ctrl-Tab may work
Alt-W 2 should work
CTRL-TAB
"Everybody is ignorant, only on different subjects." — Will Rogers
You can also split your screen by using Windows menu bar into tiled ports. Hope this helps - John
