TIA PORTAL V13
Hakim Eng
20
Hello guys,
could you please guide me to remove TIA PORTAL V13 Completely from my pc ,
i uninstalled it through the control panel, but it still exist within the programs.
thanks in advance
What do you mean by "exist within the programs"?
You can just delete the leftover folder if that's what you mean. If you mean that it's still running, then you probably need to use Task Manager to find the location of the file, kill the process, and delete that folder. Bear in mind that other programs might also be using any shared process.
TTFN (ta ta for now)
i would like to thank you so much for your reply, now i uninstalled TIA V13 correctly, and when i want to re-install again, the directory installation path is fixed to D\TIAPORTAL; and don't have possibility to change the path to partition C or E of my hard drive.
is there any suggetion please ?
thanks in advance
Search the registry with regedit to find "tiaportal" and see if any keys remain.
