jjvande
- Jan 27, 2005
- 2
does anyone know if there is such a thing as a compression force transducer with a built in thrust bearing/s? This particular project involves a rotating assembly that is preloaded axially. I need a way to allow the assembly to rotate and have the force transducer stay put so cables dont get tangled, yet still measure the axial compression force. picture the end stock on a lathe that can measure the preload it is applying to the work.
the other solution i see is to get seprate parts ( bearings/transducer) and make them somehow fit together with some sort of fixturing.
