Karlis
- Jan 8, 2015
- 79
Hey everyone,
great help from you guys as always, which is what made me come here in another quest.
What I have here is a reverse engineering project.
It consists of multiple splines, generated by performing section analysis on a scanned facet body. I have also added some studio splines manually to give it some guide curves.
Here is the model:
To me this looks a lot like a need to create "through curve mesh" surface.
But whenever I do, I either get an error "strings cross or bad selection" or the surface that is generated is messed up real bad. It twists multiple times along the center axis and comes out with huge spikes. Nothing that I thought of changing really helped this problem which is weird, because I have successfully used this feature many times before on similar models.
I also uploaded the file to ENGINEERING.com so anyone willing to help can take a closer look.
Thank you for your time!
Here is the model:
