thread561-332871 how could I add
Fabio Sena
Automotive
Mar 25, 2019
1
thread561-332871
how could I add more TEXTBOX in this case, I would like to have at least 6 TEXTBOX, this example is wonderful, but I can not open via VISUAL BASIC correctly. If someone can show me how to add one more would be incredible.
Below is code for 6 textboxes:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports System.Windows.Forms
Module Module1
	Dim theSession As Session = Session.GetSession()
	Public workPart As Part = theSession.Parts.Work
Sub Main()
	Dim myDialog As New Dialog1
	myDialog.ShowDialog()
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
	'Unloads the image when the NX session terminates
	GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
End Function
End Module
Public Class Dialog1
	Private myAttributeTitle1 As String = "Attrib 1"
	Private myAttributeTitle2 As String = "Attrib 2"
	Private myAttributeTitle3 As String = "Attrib 3"
	Private myAttributeTitle4 As String = "Attrib 4"
	Private myAttributeTitle5 As String = "Attrib 5"
	Private myAttributeTitle6 As String = "Attrib 6"
	Private Sub OK_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OK_Button.Click
		Me.DialogResult = System.Windows.Forms.DialogResult.OK
		workPart.SetAttribute(myAttributeTitle1, TextBox1.Text)
		workPart.SetAttribute(myAttributeTitle2, TextBox2.Text)
		workPart.SetAttribute(myAttributeTitle3, TextBox3.Text)
		workPart.SetAttribute(myAttributeTitle4, TextBox4.Text)
		workPart.SetAttribute(myAttributeTitle5, TextBox5.Text)
		workPart.SetAttribute(myAttributeTitle6, TextBox6.Text)
		Me.Close()
	End Sub
	Private Sub Cancel_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Cancel_Button.Click
		Me.DialogResult = System.Windows.Forms.DialogResult.Cancel
		Me.Close()
	End Sub
	Private Sub Dialog1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
		Try
			TextBox1.Text = workPart.GetStringAttribute(myAttributeTitle1)
			Catch ex1 As ApplicationException
			'attribute does not exist
			TextBox1.Text = ""
		End Try
		Try
			TextBox2.Text = workPart.GetStringAttribute(myAttributeTitle2)
			Catch ex2 As ApplicationException
			TextBox2.Text = ""
		End Try
		Try
			TextBox3.Text = workPart.GetStringAttribute(myAttributeTitle3)
			Catch ex3 As ApplicationException
			TextBox3.Text = ""
		End Try
		Try
			TextBox4.Text = workPart.GetStringAttribute(myAttributeTitle4)
			Catch ex4 As ApplicationException
			TextBox4.Text = ""
		End Try
		Try
			TextBox5.Text = workPart.GetStringAttribute(myAttributeTitle5)
			Catch ex5 As ApplicationException
			TextBox5.Text = ""
		End Try
		Try
			TextBox6.Text = workPart.GetStringAttribute(myAttributeTitle6)
			Catch ex6 As ApplicationException
			TextBox6.Text = ""
		End Try
		Label1.Text = myAttributeTitle1
		Label2.Text = myAttributeTitle2
		Label3.Text = myAttributeTitle3
		Label4.Text = myAttributeTitle4
		Label5.Text = myAttributeTitle5
		Label6.Text = myAttributeTitle6
	End Sub
End Class
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class Dialog1
	Inherits System.Windows.Forms.Form
 'Form overrides dispose to clean up the component list.
	<System.Diagnostics.DebuggerNonUserCode()> _
	Protected Overrides Sub Dispose(ByVal disposing As Boolean)
		Try
			If disposing AndAlso components IsNot Nothing Then
				components.Dispose()
			End If
		Finally
			MyBase.Dispose(disposing)
		End Try
	End Sub
 'Required by the Windows Form Designer
	Private components As System.ComponentModel.IContainer
 'NOTE: The following procedure is required by the Windows Form Designer
 'It can be modified using the Windows Form Designer.
 'Do not modify it using the code editor.
	<System.Diagnostics.DebuggerStepThrough()> _
	Private Sub InitializeComponent()
		Me.OK_Button = New System.Windows.Forms.Button()
		Me.Cancel_Button = New System.Windows.Forms.Button()
		Me.Label1 = New System.Windows.Forms.Label()
		Me.Label2 = New System.Windows.Forms.Label()
		Me.Label3 = New System.Windows.Forms.Label()
		Me.Label4 = New System.Windows.Forms.Label()
		Me.Label5 = New System.Windows.Forms.Label()
		Me.Label6 = New System.Windows.Forms.Label()
		Me.TextBox1 = New System.Windows.Forms.TextBox()
		Me.TextBox2 = New System.Windows.Forms.TextBox()
		Me.TextBox3 = New System.Windows.Forms.TextBox()
		Me.TextBox4 = New System.Windows.Forms.TextBox()
		Me.TextBox5 = New System.Windows.Forms.TextBox()
		Me.TextBox6 = New System.Windows.Forms.TextBox()
		Me.SuspendLayout()
		'OK_Button
		Me.OK_Button.Anchor = System.Windows.Forms.AnchorStyles.None
		Me.OK_Button.Location = New System.Drawing.Point(179, 373)
		Me.OK_Button.Margin = New System.Windows.Forms.Padding(6, 6, 6, 6)
		Me.OK_Button.Name = "OK_Button"
		Me.OK_Button.Size = New System.Drawing.Size(122, 42)
		Me.OK_Button.TabIndex = 7
		Me.OK_Button.Text = "OK"
		'Cancel_Button
		Me.Cancel_Button.Anchor = System.Windows.Forms.AnchorStyles.None
		Me.Cancel_Button.DialogResult = System.Windows.Forms.DialogResult.Cancel
		Me.Cancel_Button.Location = New System.Drawing.Point(435, 373)
		Me.Cancel_Button.Margin = New System.Windows.Forms.Padding(6, 6, 6, 6)
		Me.Cancel_Button.Name = "Cancel_Button"
		Me.Cancel_Button.Size = New System.Drawing.Size(122, 42)
		Me.Cancel_Button.TabIndex = 8
		Me.Cancel_Button.Text = "Cancel"
		'Label1
		Me.Label1.Location = New System.Drawing.Point(18, 22)
		Me.Label1.Margin = New System.Windows.Forms.Padding(6, 0, 6, 0)
		Me.Label1.Name = "Label1"
		Me.Label1.Size = New System.Drawing.Size(183, 48)
		Me.Label1.TabIndex = 0
		Me.Label1.Text = "Attribute1:"
		'Label2
		Me.Label2.Location = New System.Drawing.Point(18, 78)
		Me.Label2.Margin = New System.Windows.Forms.Padding(6, 0, 6, 0)
		Me.Label2.Name = "Label2"
		Me.Label2.Size = New System.Drawing.Size(183, 48)
		Me.Label2.TabIndex = 0
		Me.Label2.Text = "Attribute2:"
		'Label3
		Me.Label3.Location = New System.Drawing.Point(18, 133)
		Me.Label3.Margin = New System.Windows.Forms.Padding(6, 0, 6, 0)
		Me.Label3.Name = "Label3"
		Me.Label3.Size = New System.Drawing.Size(183, 48)
		Me.Label3.TabIndex = 0
		Me.Label3.Text = "Attribute3:"
		'Label4
		Me.Label4.Location = New System.Drawing.Point(18, 188)
		Me.Label4.Margin = New System.Windows.Forms.Padding(6, 0, 6, 0)
		Me.Label4.Name = "Label4"
		Me.Label4.Size = New System.Drawing.Size(183, 48)
		Me.Label4.TabIndex = 0
		Me.Label4.Text = "Attribute4:"
		'Label5
		Me.Label5.Location = New System.Drawing.Point(18, 245)
		Me.Label5.Margin = New System.Windows.Forms.Padding(6, 0, 6, 0)
		Me.Label5.Name = "Label5"
		Me.Label5.Size = New System.Drawing.Size(183, 48)
		Me.Label5.TabIndex = 0
		Me.Label5.Text = "Attribute5:"
		'Label6
		Me.Label6.Location = New System.Drawing.Point(18, 302)
		Me.Label6.Margin = New System.Windows.Forms.Padding(6, 0, 6, 0)
		Me.Label6.Name = "Label6"
		Me.Label6.Size = New System.Drawing.Size(183, 48)
		Me.Label6.TabIndex = 0
		Me.Label6.Text = "Attribute6:"
		'TextBox1
		Me.TextBox1.Location = New System.Drawing.Point(179, 22)
		Me.TextBox1.Margin = New System.Windows.Forms.Padding(6, 6, 6, 6)
		Me.TextBox1.Name = "TextBox1"
		Me.TextBox1.Size = New System.Drawing.Size(526, 29)
		Me.TextBox1.TabIndex = 1
		'TextBox2
		Me.TextBox2.Location = New System.Drawing.Point(179, 78)
		Me.TextBox2.Margin = New System.Windows.Forms.Padding(6, 6, 6, 6)
		Me.TextBox2.Name = "TextBox2"
		Me.TextBox2.Size = New System.Drawing.Size(526, 29)
		Me.TextBox2.TabIndex = 2
		'TextBox3
		Me.TextBox3.Location = New System.Drawing.Point(179, 133)
		Me.TextBox3.Margin = New System.Windows.Forms.Padding(6, 6, 6, 6)
		Me.TextBox3.Name = "TextBox3"
		Me.TextBox3.Size = New System.Drawing.Size(526, 29)
		Me.TextBox3.TabIndex = 3
		'TextBox4
		Me.TextBox4.Location = New System.Drawing.Point(179, 188)
		Me.TextBox4.Margin = New System.Windows.Forms.Padding(6, 6, 6, 6)
		Me.TextBox4.Name = "TextBox4"
		Me.TextBox4.Size = New System.Drawing.Size(526, 29)
		Me.TextBox4.TabIndex = 4
		'TextBox5
		Me.TextBox5.Location = New System.Drawing.Point(179, 244)
		Me.TextBox5.Margin = New System.Windows.Forms.Padding(6, 6, 6, 6)
		Me.TextBox5.Name = "TextBox5"
		Me.TextBox5.Size = New System.Drawing.Size(526, 29)
		Me.TextBox5.TabIndex = 5
		'TextBox6
		Me.TextBox6.Location = New System.Drawing.Point(179, 299)
		Me.TextBox6.Margin = New System.Windows.Forms.Padding(6, 6, 6, 6)
		Me.TextBox6.Name = "TextBox6"
		Me.TextBox6.Size = New System.Drawing.Size(526, 29)
		Me.TextBox6.TabIndex = 6
		'Form1
		Me.AcceptButton = Me.OK_Button
		Me.AutoScaleDimensions = New System.Drawing.SizeF(11.0!, 24.0!)
		Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
		Me.CancelButton = Me.Cancel_Button
		Me.ClientSize = New System.Drawing.Size(741, 448)
		Me.Controls.Add(Me.Cancel_Button)
		Me.Controls.Add(Me.OK_Button)
		Me.Controls.Add(Me.TextBox1)
		Me.Controls.Add(Me.TextBox2)
		Me.Controls.Add(Me.TextBox3)
		Me.Controls.Add(Me.TextBox4)
		Me.Controls.Add(Me.TextBox5)
		Me.Controls.Add(Me.TextBox6)
		Me.Controls.Add(Me.Label1)
		Me.Controls.Add(Me.Label2)
		Me.Controls.Add(Me.Label3)
		Me.Controls.Add(Me.Label4)
		Me.Controls.Add(Me.Label5)
		Me.Controls.Add(Me.Label6)
		Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog
		Me.Margin = New System.Windows.Forms.Padding(6, 6, 6, 6)
		Me.MaximizeBox = False
		Me.MinimizeBox = False
		Me.Name = "Dialog1"
		Me.ShowInTaskbar = False
		Me.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent
		Me.Text = "Dialog1"
		Me.ResumeLayout(False)
		Me.PerformLayout()
	End Sub
	Friend WithEvents OK_Button As System.Windows.Forms.Button
	Friend WithEvents Cancel_Button As System.Windows.Forms.Button
	Friend WithEvents Label1 As System.Windows.Forms.Label
	Friend WithEvents Label2 As System.Windows.Forms.Label
	Friend WithEvents Label3 As System.Windows.Forms.Label
	Friend WithEvents Label4 As System.Windows.Forms.Label
	Friend WithEvents Label5 As System.Windows.Forms.Label
	Friend WithEvents Label6 As System.Windows.Forms.Label
	Friend WithEvents TextBox1 As System.Windows.Forms.TextBox
	Friend WithEvents TextBox2 As System.Windows.Forms.TextBox
	Friend WithEvents TextBox3 As System.Windows.Forms.TextBox
	Friend WithEvents TextBox4 As System.Windows.Forms.TextBox
	Friend WithEvents TextBox5 As System.Windows.Forms.TextBox
	Friend WithEvents TextBox6 As System.Windows.Forms.TextBox
End Class
With best regards
Michael
You will need Windows form designer to edit the table.
"It is impossible to make anything foolproof because fools are so ingenious."
