'This callback allows the dialog to enable/disable the OK and Apply button.
Ehaviv
Computer
Jul 2, 2003
1,012
Hi
The doc say:
'This callback is executed when any block (except the ones which receive keyboard entry such as Integer block) receives focus.
'This callback is executed when block which can receive keyboard entry, receives the focus.
But for enableOKButton_cb it only say:
But not 'This callback is executed when
Do someone know when This callback is executed ?
Code:
    'Callback Name: focusNotify_cb
    Public Sub focusNotify_cb(ByVal block As BlockStyler.UIBlock, ByVal focus As Boolean)
        Try
            '---- Enter your callback code here -----
            'msgbox(block.ToString & "  -  " & focus.ToString)
        Catch ex As Exception
            '---- Enter your exception handling code here -----
            theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString)
        End Try
    End Sub
    'Callback Name: keyboardFocusNotify_cb
    Public Sub keyboardFocusNotify_cb(ByVal block As BlockStyler.UIBlock, ByVal focus As Boolean)
        Try
            'msgbox(block.Name)
            'string1.Focus
        End Try
    End Sub
    'Callback Name: enableOKButton_cb
    Public Function enableOKButton_cb() As Boolean
        enableOKButton_cb = IsEnableOkButton
        Try
            'Return IsEnableOkButton
        End Try
    End Function
enableOKButton_cb gets called after every interaction with the dialog. You have the option to check if all the required inputs have been satisfied or not. You can return true to enable the OK button or false to disable it.
Suresh
Hi ufsure and thank you.
That's strong my guess.
Thanks.
