Guest
Need a about 4mm thermal insulator for floor of a ripening room whose head space is limited. All sides of the room is 4" Polyurethane except the floor. The room operating temperature is between 13-20 deg. C.maintaining a 95% Relative Humidity.
The room is located in 15th floor of the building and we are worried of condensation at the 14th floor. The concrete floor slab is 8" thick.
Do we need to put an insulation or the 8" concrete floor slab is enough to prevent heat transfer to the 14th floor and avoid the condensation.
