raingal79
Chemical
- Mar 27, 2003
- 16
Dear all,
I would like to ask for some advise regarding thermal expansion of liquid in a pipe. There are 2 cases:
1) For liquid trapped in a pipe without external heat source except from the surrounding, I want to know how can I calculate the increase in the pipe pressure if I know the expansion in liquid volume. If I can calculate this, then I will know if the pipe can withstand the delta increase and if a RV is required.
2) Heated liquid is pumped to a header through an insulated pipe. Is it true to say - thermal expansion is not a problem in this case if the liquid is trapped? Because the insulation is to maintain the temperature. Tendency would be for the pipe to cool down rather than to be heated up and expand.
Thanks.
Raingal
Thanks.
Raingal
